TN 70 radiator flush
   / TN 70 radiator flush #1
crazyhorsemd
cincinnati, Ohio
2000 New Holland TN70, 1974 White 1370
Need to know where the radiator drain petcock is located. Want to drain / flush system before winter but can not seem to find a drain plug on the radiator. Does it even have one or am I supposed to pull the bottom hose and drain it that way. That would be a true pain if the water is hot.
Thanks
   / TN 70 radiator flush #3
Thanks
Bottom radiator hose has a ridged tube with a plug that is removable.The tn65 also has a block drain,takes a 27mm socket to remove it.
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2014 International Maxxforce DT (A53317)
2014 International...
20701 (A55853)
20701 (A55853)
2013 Dodge Journey SE SUV (A55853)
2013 Dodge Journey...
