TN 70 radiator flush
   / TN 70 radiator flush #1
crazyhorsemd
cincinnati, Ohio
2000 New Holland TN70, 1974 White 1370
Need to know where the radiator drain petcock is located. Want to drain / flush system before winter but can not seem to find a drain plug on the radiator. Does it even have one or am I supposed to pull the bottom hose and drain it that way. That would be a true pain if the water is hot.
   / TN 70 radiator flush #3
Bottom radiator hose has a ridged tube with a plug that is removable.The tn65 also has a block drain,takes a 27mm socket to remove it.
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2005 International 7400 Chassis Truck, VIN # 1HTWGAAT75J048748 (A51572)
2005 International...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
