TLB 110 laboring climbing slopes
   / TLB 110 laboring climbing slopes #1
roygul
Brisbane North
Jd 2305,Antonio Carraro trx 9400, JD 10 TLB
Only have about 25 hours on mine so far. When I climb my slopes 20 - 25 degrees ( not working on that just traversing straight up and down ). The machine labors in low. Is this normal ?
Cheers
Byron
   / TLB 110 laboring climbing slopes #2
In low range, that is not normal at all.
I'll give few details on what I mean by laboring. Revs set at about 2500, hit the slope in A range. Revs drop to about 2000, and vary a little lower /higher depending on the steepness of the slope.
Cheer
Byron
   / TLB 110 laboring climbing slopes #4
Do you have Load Match turned on? If not this sounds normal. If you do have LM on something is wrong becuase LM lowers ground speed to maintain rpm.
Matt
   / TLB 110 laboring climbing slopes #5
I think that is normal, this is a 43 hp tractor that weighs 7,600 lbs. The 110 will seem a bit sluggish compared to lighter higher hp tractors.
It should be able to push into a pile of dirt without bogging down much in A range, that has been my experience.
   / TLB 110 laboring climbing slopes #6
Yep... they're heavy buggers! Lot's of iron in a small package.
When the tractor begins to pull down rpm's - ease off the forward hyd pedal. You'll lose some speed; but, the tractor won't bog down 500 rpm! Should stay within 100-200 rpm of the initial throttle setting.
The last thing you should do is - push the pedal down even farther!
AKfish
   / TLB 110 laboring climbing slopes #7
Matt
The 110 tlb has load match built in. It can not be turned off like a 4xxx series. I agree that 500 rpm drop seems like a lot, but 20 -25% grade is pretty darn steep.
I think everything is ok. It is a heavy machine for the hp, it digs fine. Finished off a nice track around a dam today.
Very happy with the machine. Just thought I would check.
Thanks all.
Byron
John Deere Bale Spear (A55218)
John Deere Bale...
2018 CATERPILLAR 415F2 IL SKIP LOADER (A52705)
2018 CATERPILLAR...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2015 TAKEUCHI TB260 EXCAVATOR (A52705)
2015 TAKEUCHI...
