3-Point Hitch TLB 110 3 point hitch
   / TLB 110 3 point hitch #1
ugo4it
South shore,Nova Scotia, Canada
TLB 110
I have a 110 with no 3 point hitch and I want to fix this. Does anyone with TLB 110 have any pictures and measurement for the 3 point hitch toplink, arms and sway supports and so on?
One other option is get this info to mntviewranch (Fit Rite Hydraulics) and have set made. I seen on his site the TLB 110 is not listed. I have the three rear remotes so this is a very nice option.
So any info. would be great.
Randy
   / TLB 110 3 point hitch #2
I'll get more detailed pics when it gets home but, I'll start with these. I forgot I had these, but took them for another member. They aren't the best, though.
   / TLB 110 3 point hitch #3
If you are starting from scratch consider a Top-n-Tilt kit. I have one from JD and it is much more versatile than the plain 3pt arms.
   / TLB 110 3 point hitch #4
He is going for a TnT, but I he's eyeing Brian's kit instead of Deere's. I can't say I'd blame him, save some money for the same basic thing. Another place to save is finding a 4000 series left over 3ph kit instead of new.
Does the kits from JD or fit rite hyd(Brian) come complete? Or do they assume you have the 3 point parts to start with. I need to get all the parts as I have none now, I would need top link, lifting arms and adjustment arms and sway links.
   / TLB 110 3 point hitch #7
Whether you get Brian's or not, you'll have to get all the links. I believe he only sells the cylinders. The links will have to come from JD or find a used pair like I posted above.
   / TLB 110 3 point hitch #9
ugo4it said:
The kit from JD look to be complete from the pictures.
What state is Cabot in?
I believe it's Arkansas. Not sure, though.
   / TLB 110 3 point hitch #10
What I would do if the set in Cabot doesn't work out is buy a set of telescopic arms from the Deere dealer and then buy the hydraulics from Brian.
This way you have the telescopic links which are much easier to hook to the big boxblades. The top n tilt is just way better too.
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
96in Large Capacity Bucket (A49251)
96in Large...
2025 JMR 40in Stump Bucket Skid Steer Attachment (A49346)
2025 JMR 40in...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A46684)
2002 Ford F-150...
2014 FREIGHTLINER 114SD TIRE TRUCK (A47371)
2014 FREIGHTLINER...
2010 Ford E-150 Cargo Van (A46683)
2010 Ford E-150...
