Tl80 fuel
   / Tl80 fuel #1
jimbo1955
Ellenboro NC
Bobcat 753
I have a tl80 that keeps running out of fuel you can prime filter and bleed injectors it will run about 3 minutes and will run out of fuel again any suggestions
   / Tl80 fuel #2
The first thing I would do is check the screen in lift pump, then remove the banjo bolt and fitting from the inlet side of said pump. Remove the fitting completely from the hose, then inspect all of those components for debris wedged into passages. If that's all clear, then using a jug of clean fuel and an adequate length of fuel hose, set up an auxiliary supply to that same fitting. Bleed it out again, start it up and see how long it runs.
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
