Tl80 fuel
   / Tl80 fuel #1
jimbo1955
Ellenboro NC
Bobcat 753
I have a tl80 that keeps running out of fuel you can prime filter and bleed injectors it will run about 3 minutes and will run out of fuel again any suggestions
   / Tl80 fuel #2
The first thing I would do is check the screen in lift pump, then remove the banjo bolt and fitting from the inlet side of said pump. Remove the fitting completely from the hose, then inspect all of those components for debris wedged into passages. If that's all clear, then using a jug of clean fuel and an adequate length of fuel hose, set up an auxiliary supply to that same fitting. Bleed it out again, start it up and see how long it runs.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
Informational Lot - Financing (A53473)
Informational Lot...
2013 PETERBILT 367 DAYCAB (INOPERABLE) (A52472)
2013 PETERBILT 367...
2006 International 9400i (A52748)
2006 International...
