TL70 wont start
   / TL70 wont start #1
robdogtn
NH TL70
Okay, I am puzzled, but I may be close....
My TL70 has new battery, new terminal ends, has been starting and running fine until yesterday. Now, when I turn key on, everything is as should be, every gauge moves, radio works, a/c works, etc. But, when I engage the clutch to start, everything dies. Is there a switch or something that has probably gone bad?
Thanks in advance.
   / TL70 wont start #2
Thanks in advance.
Try to find a circuit diagram to help you trouble shoot this. I'm not familiar with the specifics of
your tractor.
Usually there is a seat swich, a pto switch, and a clutch switch that have to be in the closed position to energize the starter solenoid. I think the lights go out to provide max current for starting when the the key switch moves from RUN to START but the starter circuit is open the starter isn't engaging.
That's where I'd look for bad key switch or loose wire, a bad safety switch, a bad solenoid, or bad solenoid ground.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
