TL3200 hydraulic pump drive slipping
   / TL3200 hydraulic pump drive slipping #1
mopacman
Independence, MO.
Iseki 3200F, kubota L245DT
After I added a koyker loader to my TL3200 the pump drive gear train started makeing noise. it sounds like gear teeth slipping. I was running about 2500lbs pressure when this started. I have reduced my pressere to 2000lbs. but when I turn the power steering all the way to the stop with 2000lbs pressure I hear this same noise. It looks like both pumps run off of the same gear drive. Does any body have any idea what is in there that I broke, and where can I get parts to fix it.......thanks Larry
   / TL3200 hydraulic pump drive slipping #2
If I'm interpreting the parts book correctly the hydraulic pumps are chain driven . Your chain is probably stretched & jumping. Sprockets & chain will probably need replacing.
thanks for the info. I had not thought of that.....Larry
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
Landhonor RSB-14-80W, 80" Rock Bucket (A52384)
Landhonor...
2022 Adams CLC-1013 Conveyor - New (A53473)
2022 Adams...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
