TL3200 hydraulic pump drive slipping
   / TL3200 hydraulic pump drive slipping #1
mopacman
Independence, MO.
Iseki 3200F, kubota L245DT
After I added a koyker loader to my TL3200 the pump drive gear train started makeing noise. it sounds like gear teeth slipping. I was running about 2500lbs pressure when this started. I have reduced my pressere to 2000lbs. but when I turn the power steering all the way to the stop with 2000lbs pressure I hear this same noise. It looks like both pumps run off of the same gear drive. Does any body have any idea what is in there that I broke, and where can I get parts to fix it.......thanks Larry
   / TL3200 hydraulic pump drive slipping #2
If I'm interpreting the parts book correctly the hydraulic pumps are chain driven . Your chain is probably stretched & jumping. Sprockets & chain will probably need replacing.
thanks for the info. I had not thought of that.....Larry
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED AGT SAWMILL MODEL - YC32G (A51248)
UNUSED AGT SAWMILL...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
Adams 6T Fertilizer Spreader (A53472)
Adams 6T...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
