TL2700 starting issues
   / TL2700 starting issues #1
bapos
I have had very good help here so I am going to the well again if I can?
Iseki tl2700. We had to have some electrical work done from my tractor repair center and they did a very good job.
Recently we have had a issue with terminal ends on the battery and got those corrected but for some reason now when you turn the key to start it you can hear the solinoid engauge but does not turn the engine?
Not sure if we have a shim problem... a starter problem or what. Any general tips to try and whittle my problems down would be appreciated.
Thanks in advance.
Bapos
   / TL2700 starting issues #2
Have you checked the ground strap/frame connection?
Its definately the starter. I took it off and attempted to have it turn and the bendix comes out but does not turn.
Took to a starter rebuilder and said it would take 3 weeks and 225.00 which I think is too high and too long.
Any ideas here?
   / TL2700 starting issues #6
Go to another shop!!!!!!!!!!!!!!!!..........The exact same thing happened last spring on my TL 2300. Took it to my local starter alternator repair shop...out the door with a complete rebuild for $80. He even painted it.........God bless the good guys......Dennis
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
2001 John Deere M665 (A50120)
2001 John Deere...
New Holland B95 Backhoe (A50490)
New Holland B95...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
