TL2300 Hydraulic Fluid
/ TL2300 Hydraulic Fluid #1
pchearn
Hi. I'm new to this forum. I own an Iseki TL2300. I've had it for several years. I don't really know anything about repairing it. I've changed the oil, but that's about it. I had it repaired a couple of times (nothing serious) where I bought it, but they no longer repair Iseki tractors. I have a frontend loader on it and it's not working right. I decided to check the hydraulic fluid, and discovered that I don't even know where to check it. There's a dipstick and a filler cap on the thing the gear shifter is on, but I believe that is where the gear oil goes. Can anyone point me in the right direction with this frontend loader problem? If this question needs to be listed in the Parts/Repairs forum, please let me know. Thanks in advance.
/ TL2300 Hydraulic Fluid #4
FOR SURE.......its that opening with a plug there by the gear shift lever. The one you knock off when your foot drags across it getting in.............It uses the same reservoir for FEL, 3PH, and trans.............I check it without the unit running and fill it up to the line......Good Luck......Dennis
Dennis - OK, great! Thanks. I know what you mean about he plug. It would have been better if it screwed in. Now do I fill it up with gear oil or hydraulic fluid? It looks like it currently has gear oil in it.
/ TL2300 Hydraulic Fluid #6
Universal tractor hydraulic fluid...............Get a 5 gallon or 2 gallon container at Tractor Supply or another vendor. It doesnt "go bad" and over time you will use it. Hydraulic fluid is like 10 wt versus gear oil which is like 90 wt...................NO way to use the heavy stuff........Good luck.......Dennis
PS.......For that plug/cover, I lost it eventually and made a plug out of a dowel rod painted it orange. Every now and then, when I am mounting up I give it a little downward push with my heel........Been several years now and NO problems.........Dennis
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2025 44in. HWG44 Hydraulic Mini Log Grapple Skid Steer Attachment (A59228)
2025 44in. HWG44...
