tl100a surges in road gear going up hills
   / tl100a surges in road gear going up hills #1
ft52
Fayetteville Tx
2006 NEW HOLLAND TL100A, 1986 John Deere 2150. 1954 Farmall Super H Stage 2 .1964 Farmall cub. 1948 farmall cub. 1941 Farmall B
new Holland tl100a surges going uphill 1 mile per hour difference.
   / tl100a surges in road gear going up hills #2
could be bumping against governor back off a little on throttle and see if this continues
   / tl100a surges in road gear going up hills #4
I suspect you have a problem with the governor. The rpm shoud droop a bit when you start up hill but if I understand you correctly, the speed goes up and down so the governor is "hunting". it need more damping.
Have you tried to NH forum below? Someone like Dieseltech or RickB maybe able to help.
   / tl100a surges in road gear going up hills #5
G'day hate to say it but it can be a prob with them I have had to have a couple of inj pumps rebuilt now due to surging and it was found to be the governor springs at fault
Jon
   / tl100a surges in road gear going up hills #6
Expensive spring
Jon
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
70007 (A51691)
70007 (A51691)
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
