tl-1900 starter solenoid fried....
   / tl-1900 starter solenoid fried.... #1
willty
hi,bill here.cant seem to find a starter solenoid for my machine !...i am dead in the water.info..nikko#021000-4390/...581100-1232......solenoid part#581151-0400.the after market from my local is adifferent starter and my steering rod hits otherwise it would probrobly work..i was told the tl machinesw/ power steering are a problem.i have sent it out only to be told cant get the solenoid.....thanks again...maybe reroute steering?
   / tl-1900 starter solenoid fried.... #2
A couple different starters are listed in the parts books for your tractor. Are these #s off of the starter?
hi len,the numbers are off the starter itself....only the solenoid number is out of the book.thanks bill
   / tl-1900 starter solenoid fried.... #4
There doesn't appear to be a replacement solenoid other than ordering one from Japan. Which is probably pretty expensive. I did find one that was supposed to fit, but it was 24 volt. I have found a replacement starter.
   / tl-1900 starter solenoid fried.... #5
Howdy Len , Glad You found a Replacement , Would You Mind Sharing What You found that Worked for Others that Might be Needing help in the Future .
I Had a Friend that said a Starter & Cellenoid off of a Isuzu engine at a Auto parts Worked on His . for 35 Bucks . But Never got the Part or model # from Him . Or I Would have Posted it for You. Thanks Bob .
   / tl-1900 starter solenoid fried.... #6
Yes,please follow up with your results. I have a 1900 and am in need of a replacement starter. Thanks.
good news, sutton tractor was able to rebuild the solenoid thanks all.(especially len scheafer)
(9) First Cutting Grass Round Bales (A50515)
(9) First Cutting...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Dingo TX427 Mini Skidloader (PARTS) (A50774)
Dingo TX427 Mini...
Horse Hay Feeder (A50515)
Horse Hay Feeder...
2018 GMC Savana (A50120)
2018 GMC Savana...
Grasshopper 722D Zero Turn Mower (A50514)
Grasshopper 722D...
