TL 100A
   / TL 100A #1
David2222
kingsport, tn
new holland tl100a
I just purchased a used 2007 TL100A tractor, 4WD, Cab, 830TL Loader. It has 12/12 Transmission. Any advice, tips, tricks or suggestions would be appreciated.
   / TL 100A
No, I have an Allis Chalmers 7030 and had a John Deere 5400
   / TL 100A #4
Good, that would be a big tractor to start with. Just be careful til you get used to it.
   / TL 100A #5
1) Check all fluid levels, including front axle differential. Get an Operators Manual, if it didn't come with the tractor.
2) As soon as possible, change all the fluids and filters that you checked in #1. I start with motor oil, then anti-freeze/coolant......
Just reading that you already have 2 tractors.... you likely know the above, but it's worth me boring you with... :D
Rgds, D.
   / TL 100A
Thanks for your comments and I admire your Safety consciousness
   / TL 100A
Thanks Dave, as you suggest I plan to fully service the Tractor. I have not had any experience with New Holland and was just looking for some advice
   / TL 100A
Thanks Bob. I have read some interesting Threads and am impressed with the site
   / TL 100A #10
A well built tractor is a pretty tough machine, but they all benefit from regular maintenance - good to hear you are on-board with that already. I've had good Parts service from my nearest NH dealer, no complaints there. Have used their filters, and also Wix for oil.
Should be some other '100A folks around in a bit. Yours is not what I consider an old tractor, but you might also want to post it's Operating Hours here too.
Rgds, D.
2012 Infiniti G25 Sedan (A56859)
2012 Infiniti G25...
1991 International 4900 Box Truck (A55315)
1991 International...
2008 TOYOTA TUNDRA (A58374)
2008 TOYOTA TUNDRA...
2224 (A58376)
2224 (A58376)
SET OF 15.5-38 DUALS (A52708)
SET OF 15.5-38...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
