Titan ditch bank flail mower hydraulic fitting
   / Titan ditch bank flail mower hydraulic fitting #1
clarkharms
Lyme, CT
Kubota L3901
I recently purchased a titan flail mower however the hydraulic fittings do not match my tractors, a kubota l3901.
My thought was to change out of he fittings however even the connection on the end of the hose is odd. On the end of the hose there are tapered fittings with an o-ring in the middle of the taper and is they have female threads. I will try and post a picture if that helps?
   / Titan ditch bank flail mower hydraulic fitting #2
Could buy one set of each quick attach and make a short adapter hose that has one of each style
   / Titan ditch bank flail mower hydraulic fitting #3
and yes pictures would help
   / Titan ditch bank flail mower hydraulic fitting #4
If you send a message to TBN User Jack Yuan or post over in the Attachments forum where he is more likely to see it - I'm sure he can answer all your questions.
He is in China and works in the implement manufacturing business. As such he is EXTREMELY familiar with the various models of implements coming from over there.
He has comments in very many of the flail mower posts over there if you'd like to look him up to verify.
Good luck & come back and let us know how you like the mower once you get up and running. I have been looking at those ditch/bank mowers myself.
   / Titan ditch bank flail mower hydraulic fitting #5
If the initial couplings of the Titan ditch mower cannot fit on your L3901, then you need an adapter to change the initial thread into the thread of the male coupling for L3901.
I think the initial thread on Titan mower is G1/2" as this photo: QQ截图20180808234727.jpg
By the way, what's the thread of the male coupling for L3901? You can ask this data from your Kubota dealer.
Then you can find such adapter on internet G1/2" -----> Kubota male coupling thread.
Or you can ask Titan to get them from their Chinese vendor which should/could produce that adapter within one week.
Enjoy it.
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
2018 Mitsubishi Mirage ES 4D Hatchback (A53117)
2018 Mitsubishi...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
CASE INTERNATIONAL 12R 30" CORN HEAD (A51247)
CASE INTERNATIONAL...
1995 PACE AMERICAN 8' X 40' GOOSENECK BUNKHOUSE TL (A51247)
1995 PACE AMERICAN...
