Titan Attachments Quick Hitch Initial Review
   / Titan Attachments Quick Hitch Initial Review #1
Ledgemere Farm
Limerick, Maine
A bunch
Titan Attachments Quick hitch- A Total Waste Of Money?
Looks flimsy the QH16 is much better and has none of those issues
I’m not overly impressed by it to be honest. I left what I thought of the welds out of my video. The whole locking mechanism is really chincey
   / Titan Attachments Quick Hitch Initial Review #4
Pretty typical of any quick hitch that is produced in China with minimum standards..... This is problem in industry today... Made cheap as possible and ask exorbitant price for item....
Another issue with quick hitches and its not quick hitch specification/design fault it is implement manufacturers seem to want to ignore the standard and continue to manufacture implement attachments to their old specifications and not revamp or update design to have better compatibility change is hard for some manufacturing entities...
I have BE (Braber Equipment Ltd) Cat 1 QH with none of these issues...
Something to look at...
   / Titan Attachments Quick Hitch Initial Review #5
The hook $34.95 https://www.amazon.com/osemar-Harbor-Freight-Quick-Hitch/dp/B08W4X6TJT
Harbor Freight $140 3-Point Quick Hitch - 27-3/16 In. Clearance
willy
   / Titan Attachments Quick Hitch Initial Review #7
I'm fortunate that my tractor has the Euro hooks on it from the factory;
looking down from the cab, you can see the tractor hooks and the balls on the implement,
After backing in to the implement, you can see that I'm not perfectly level,
I've lifted the lift arms and taken the load off the parking stands,
And now I'm lowering my toplink with the rope and adjusting the length to catch,
My implement is completly on my 3 point, I'll close the latches when I lift the parking stands and connect the pto and hydraulics,
No fuss no muss. The hydraulic toplink is not factory.
   / Titan Attachments Quick Hitch Initial Review #8
Nice, simple and just works. No frame in the way either.
Most hooks will actually latch it self once the ball sits in the hook, but I've noticed some brands are a bit more stubborn and need to be manually locked. Still no big deal at all.
The top link with the hook makes for the complete combo. How have you been like it so far, Lou?
   / Titan Attachments Quick Hitch Initial Review #9
I have the HF QH and while I've had to make a few adjustments I'm please with it overall. I had to use bushings for the FM and rear blade, but I use it as is with my weight barrel and rake and BB. It's ice to back up and drop the weight barrel and then back up and attach the blade or rake w/o getting out of the seat.
I'm not using the FM much since I got my ZTM.
I'll post some pics
   / Titan Attachments Quick Hitch Initial Review #10
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A57024)
Ditch Witch 6510A...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A57193)
UNUSED LANDHERO...
2001 KOMATSU PC220LC-6LE EXCAVATOR (A52707)
2001 KOMATSU...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
