Quick Hitches Titan 3 point to SSQA Adaptor
   / Titan 3 point to SSQA Adaptor #2
I do not have the HF quick hitch. So cannot help with that.
...But I do have the Titan 3 point to SSQA. And like it for what it is. I also have a hydraulic top link, so that makes it easy to connect to SSQA attachments.
It is heavy, so a bit of a pain to connect to three point arms, I made a jig out of some scrap 2x4s and a furniture dolly, to easily roll it around, and hook up.
.. I use it mostly with my tree puller, as I use it on rear of tractor, while leaving Grapple on front. Have cleared acres of saplings with it
..Also use it for my pallet forks, and homemade platform for a carryall. And sometimes with the bucket.
That's my plan is to use it with the bucket on with the grapple on front.
With rear remotes and top tilt eventually, it'll be an interesting addition!
   / Titan 3 point to SSQA Adaptor #5
Pretty slick. I was thinking of making my tree pulled so it would do both ssqa and 3pt.
It would be cheap but a lot of bracing. This could be the way to go.
   / Titan 3 point to SSQA Adaptor #6
It wouldn't take much more bracing and would set in closer than on an adapter to SSQA.
Just copy this frame design:
On the SSQA:
Here is a puller that fits both ends from: Buckthorn Puller - Custom built attachments to fit almost any need you may have.
Well, I got it and sad to say. It will NOT work with a HF quick hitch out of the box.
What is irritating is that with only a little bit of care and setup with welding certain braces, it would work perfectly.
Titan, you screwed the pooch on this one.
By moving the two braces out in line with the other frame members, this could have worked just fine. No extra expense or labor. 5/8" inch total means 5/16" on either side.
So. It's heavily built. Seems well constructed. Must be careful with the SSQA lever handles as they can terrify the rear tail lights if the top link isn't extended out quite a bit. All in all it is a quality product. IMG_2204.JPG
Now I have to go buy a plasma cutter, sigh.... and a welder, sigh.... to move the two pieces of outer angle outwards enough to work with the QH and then of course finish contract negotiations with Brian @ Fitrite for rear remotes so it can dump as needed.
A man's work is never done.
   / Titan 3 point to SSQA Adaptor #8
Lenny double check the distance (stroke) you'll need to dump. I don't think you can fit a long enough cyl in place of the top link to make it happen.
I've tried. It's handy to have a bucket on the back for tools or loose hand filled stuff, and the rear forks are great, snowplow is handy too.
   / Titan 3 point to SSQA Adaptor #9
Seriously considered this Titan attachment as a Christmas present to myself. Sorry to hear modifications are necessary. Was thinking of attaching my SSQA 6 ft snow bucket as a rear tool carrier. Could collect firewood as well , for others, since I no longer bother with it. But have 50 acres of woods, harvested for maintenance last year, and still tops and sizable limb wood available to collect. Use hydraulic top link, so it could be practical to adjust pitch. The capacity of the 9540 above would certainly be welcomed.
   / Titan 3 point to SSQA Adaptor #10
I didn't have to make any modifications to mine, it works fine for me. I have a hydraulic top link....But I do not have a HF quick hitch.
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2003 Big Tex 10PI...
Box of Transport Ratchet Straps (A55851)
Box of Transport...
Groundhog RH14G Vibratory Articulated Tandem Smooth Drum Roller (A55851)
Groundhog RH14G...
2020 DRAGON ESP...
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
