Tires
/ Tires #1
Barryh
Harpers Ferry WV - Mountains of Shannondale
Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
Anyone have any experience with these { TIRES } I am thinking about putting a set on the PT. I'm not to much concerned about the hard ride of a 6 ply. I do a lot of work in the woods thinking they will help to ward off flats.
/ Tires
/ Tires #3
I have similar bar, or lug tires on my 1445, and they are 26X12X12 but they are 4 ply. 6 ply would be better, especially working in the woods. Keep in mind that the recommended tire pressure will change. Just adjust the tire pressure until you get a good foot print. The higher you go in plies, the maximum tire pressure will increase, and also the weight limit will increase.
/ Tires #4
/ Tires
I like the look of these, over traditional bar tires or lugs. The wife told me I had a flat this weekend after lifting the tree stump. I knew it was just the turf tires with the 2 ply sagging under the weight.
Since I do lift heavy things, and have decided not to ( shhhhhhhh whisper!!! ) reverse my wheels. /forums/images/graemlins/grin.gif I'm thinking the stiffer side walls should also increase stability some what under heavy load.
/ Tires
/ Tires
J.J.
I was just wondering how those tires ride on a hard surface with the bar setup? /forums/images/graemlins/ooo.gif
/ Tires
J.J.
/ Tires #9
Barry;
I have the bar tires on my 180. The bar tires ride very smooth on pavement and soil and they have excellent traction off road, the one drawback is snow plowing with the bar tires on pavement. I ended up buying chains for the front and back-It really made a huge difference traction wise. The bar tires are not very gentle on a damp lawn.
/ Tires
Maybe I should think about this a little more before I jump. I was pretty impressed with the traction of my turf tires this winter they were good on ice and snow. I had no problems going through deep snow up to 12 inches, or up and down icy driveways on an incline. Maybe I will just get a good 6ply turf. Thanks for the information I appreciate it.
/ Tires
Are your bar (TIRES) more like the one on the left or right? I'm thinking the tire on the left might get better traction in snow.
The bars seem more refined and closer together. I don't see any turf tires in a 6 ply. /forums/images/graemlins/shocked.gif
/ Tires #13
Like someone else said the bar tires ride just fine. All 8 of my tires are bar/lug tires. The people that had the 1445 before me kept the 26X12X12 tires inflated to 21 lbs. and I think the rim width is 10.5 in A lot of rims look similar, and have the same bolt pattern, but the center hole is different. I believe a Ditch Witch tire will fit my machine. I have purchased some tires and rims off Ebay. New stuff, half what PT would offer. If you mix tires from different manufactures, and mix different plies, rolling distance will differ, and the ride will be different. If you are going to mix tires, such as lug tires on the back, the rolling distance should be the same. To check this, a fiberglass tape around the center of the tire will measure in inches. Make sure that all tires have the same measurement. If you want to check foot print, some soft dirt will give a good indication of tire print. Lug depth should be same from center to side. Adjust tire pressure to give best tire print. You may not realize this, but when you pick up a heavy load, and move it , the foot print will change, and the tire could be operating at its max load range. The load range is different for the different ply tires. and the pressure for safe operations varies.
Fourteen came up with a different tire pressure for the front and back in an earlier post.
/ Tires
<font color="red">Fourteen came up with a different tire pressure for the front and back in an earlier post. </font>
I did notice that.
Thanks good information, and tips. I'll be buying all four from the same manufacturer.
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
