Tires tires
/ tires #1
ericbx1500
Michigan
BX2380, scotts 48
was thinking about getting a set of bar tires. am i able to use the larger tires that come on bx23 on the bx1500 /forums/images/graemlins/confused.gif
/ tires #2
</font><font color="blue" class="small">( was thinking about getting a set of bar tires. am i able to use the larger tires that come on bx23 on the bx1500 /forums/images/graemlins/confused.gif )</font>
Why not go with the BX 1500 size ag tires?
/ tires #4
Better do the math on the tire circumference ratio front to rear. The gearing for 4wd is calculated for a certain relationship in rotation on each axle.
Then, of course, there will be a loss in power from turning taller tires- probably not enough to worry about.
In 4wd trucks, they change ring & pinion gears as they go to larger tires.
/ tires #5
The BX18XX, BX22XX, and BX23 tires are a different size than the front/rears of the BX1500. I found out the hard way, order a set of the bigger tires for the same reason you are thinking. The rears "just fit" with minimum clearance between the tire and fender. The fronts did not fit at all, as the front hub assembly on the BX1500 did not allow for the larger tired to be installed. I ate them and ordered a complete set of AG's for specifically for the BX1500. I luckily found a local buyer for the "mistake" and lost about $75 on the whole thing. The set of (4) AG's for the BX1500 cost me $276 from my dealer ($39/front, and $99/rear).
/ tires
blackmajicwoman was that the price for rims and tires
Wolverine Skid Steer Land Leveler, 78" (A62679)
Wolverine Skid...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
Woods 72" 3-Pt Rotary Mower (A66408)
Woods 72" 3-Pt...
