Tires Tires
/ Tires #1
AR15MIKE
Logan,Oh
Kama TS354C
On the Kama TS354C that I bought I was thinking on switching sides on tires so I can flip them around to give me a wider wheelbase and adding wheel weights. Any words of wisdom? I use it in the hills so it couldn't hurt I would think.
/ Tires #2
Hi Mike, I've done this with the front wheels of my Jinma 284.
However, it was not a good move because I have a front loader bucket that is now narrower than the width between the wheels. Harder to get into corners with the bucket to clean up loose stuff. You also have the air valves on the inside of the wheels. Having pointed out those observations I've frightened myself a few times on uneven surfaces having the feeling the tractor is going to roll. I understand your concern, if you don't have a FL then I would definitely go for it if I were you. All the best Andy
/ Tires #3
Go for it! I did my Farm Pro 25 hp 4x4 on the rears only and it is a lot more stable. I not only switched sides (to keep the tread lugs going the right way) but also put the rims on the outside of the hubs for even more width. I have had no regrets.
/ Tires #4
I did the same as VAVTX on my 284 and it does help a lot. Turning the rims around will give you an even wider stance as was stated by VAVTX. I have an FEL so I didn't do the front.
Mark H
1999 22ft. Haulmark VN822CCE-102 T/A Enclosed Cargo Trailer (A66738)
1999 22ft...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
2021 POLARIS PRO XD 4000D UTV (A65057)
2021 POLARIS PRO...
2004 (INOPERABLE) INTERNATIONAL TRANSTAR 8600 (A67714)
2004 (INOPERABLE)...
2018 PETERBILT 579 (A67714)
2018 PETERBILT 579...
2012 PETERBILT 587 (A67714)
2012 PETERBILT 587...
