Tires
/ Tires #1
Farmerpops
Kabota BX2380
Does anyone know of a non flat tire. Kabota 18-8.5-10.
/ Tires #2
You can have any tractor tire foamed.
When foam cures it is a heavy solid, completely filling the tire.
There is no residual air in the tire so ride is a bit harsher.
Impossible to deflate.
Kevlar ply demolition tires are also sold. Small volume category. Expensive.
Also a bit harsher in ride because demolition tires are minimally flexible.
Recycled aviation tires are another option. (GENSCO)
MORE: Comparing Types of Liquid Tire Ballast | OrangeTractorTalks
VENDERS: Agriculture Tires
All Forestry Tires and Skidder Tires
/ Tires #3
:welcome:
:tractor: I'm going to move this thread over to our tires section of the forum.
/ Tires #4
Foam fill the tires at a tire shop that specializes in it. Adds about 25 pounds per tire. They can match the hardness to the PSI rating of the tire.
Do not use expanding foam from a can. They are not the same thing.
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
AUCTION STARTS HERE @ 9AM (A63291)
AUCTION STARTS...
2020 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 MACK ANTHEM...
2021 Bobcat UV34 4x4 Utility Cart (A61572)
2021 Bobcat UV34...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
