Tires Tires, sort of... and wheel spacers
   / Tires, sort of... and wheel spacers #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
Snow plow... and wheel spacers???
When we replaced our big, heavy L3130 with a more petite L3400, we also got rid of the L3130's filled R-4 tires and got nice fat turf tires with the L3400. The better not to squash the lawn with, my dear, and having had turfs before, I preferred how they work in snow. In order to get traction to use the loader, and more importantly, if it ever snows again, the SSQA snow plow, I built a ballast box which probably adds 600 lbs. on to the 3-point. The previous owner used it in mostly for finish mowing, with a 6' rear deck, so he didn't need any additional weight.
Now, to the point: I am considering adding some Kubota wheel spacers in the rear- 1.75" each side. My thoughts are that the wider track will help offset the tendency for the 78" HLA plow to push the front of the tractor around- a little more stability. I know the plow should be a 72", but it was perfect for the old L3130, and since I already had it... Does anyone have any experience with what I want to do? The rear axle seems pretty heavy duty, so I am not so worried about spreading the wheels and damaging the rear end. Of course, hill side stability will be improved, and the extra width shouldn't cause any other issues I can fore see.
   / Tires, sort of... and wheel spacers #2
Along a slightly different thought, all that weight on the 3-point unloaded the front wheels, so they are less able to steer the tractor. Adding some weight on the front might help too.
Sort of forgot about posting this... I was able to get a deal I couldn't refuse on the spacers, and since the same guy had some ladder style chains for my sized rear turfs, also cheap, it was a no-brainer. But, ever try to find some decent M16- 1.5 metric nuts? Wound up buying them from a Kubota dealer. Ugh. He also had what I thought (hoped might be a better word) was a crossover relief valve... turned out to be a pilot operated load check valve. Hoping to find someone who can use it via eBay, since I don't think I will ever need it.
P1010762.jpgP1010765.jpgP1010759.jpgP1010768.jpg,
Quick Attach Pallet Forks (A47384)
Quick Attach...
Mini Forks (A50322)
Mini Forks (A50322)
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
UNUSED TOPCAT QUICK ATTACH STUMP GRINDER (A51244)
UNUSED TOPCAT...
