Tires in the snow
   / Tires in the snow #1
Pks
Platinum Member
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
For those of you who have Ag tires, how well do you like them in the snow and in sand?
I have R4s that are garbage in snow and sand. I use chains to help.
Peter
   / Tires in the snow #2
I have ags on my tractor, and they're very good in snow. I've never taken my tractor to the beach (Am I depriving the poor thing?), so I don't know about sand. /w3tcompact/icons/laugh.gif
But if the snow is very deep and heavy it can slip, so I invested in a set of double ring chains. Now it feels like it can go through anything!/w3tcompact/icons/shocked.gif I cleaned up the thick ice of an ice storm (several inches of frozen snow and ice) with my backblade, and never slipped at all! /w3tcompact/icons/smile.gif
Rich
"What a long strange trip it's been."
   / Tires in the snow #3
<font color=blue>...I have R4s that are garbage in snow and sand.</font color=blue>
I'm amazed to hear this, because last night I went out plowing snow with R4s and nothing but a 250 lb. dirt scoop on the back, and I had no trouble whatsoever. I can only imagine what the R1s with chains must be like if they can put these R4s to shame.
Bob
   / Tires in the snow #4
I bought a JD 4400 and it had the R-4 tires(I could not get R-1 tires when I bought the tractor,a month wait at least)I tried the R-4 for a year and they failed miserably for my application,I bought the R-1 tires through my dealer and it was like I moved up a tractor size/w3tcompact/icons/smile.gif,not to mention the great traction. I asked my dealer here in WV(Hayhurst) if he would give me an allowance on trading when I ordered the R-1's and he said we will cross that bridge when we come to it,I ended up crossing the bridge myself,and I have a set of R-4's in my barn collecting dust./w3tcompact/icons/frown.gif
   / Tires in the snow #5
I have ag. tires. So far they have done quite well in snow on my step driveway. They also do well in the soft mud and clay that I seem to have too much of. I don't have any experience in sand, but I would expect that ags. would be superior to R4s. Paddle tires seem to be the best in sand, and ags. are the closest thing to a paddle. Just a thought.
   / Tires in the snow #6
I have Ag's on both my tractors and they are decent in snow, good in soft dirt and mud, ice is a different story. I have chains on the Ford 8N for added traction in the winter. So far the 4WD on the Kubota has been SO much better that I think I can get away without chains.
I have a friend with R4's on his Kubota Grand L. He likes the lawn frienldy aspect of the R4's vs. Ag's, but when it came to performance in the snow the R4's were not that much better than when he had turfs on it.
Randy
   / Tires in the snow #7
I use ags with no chains and have used it in over 18" of pure mud when I was moving a dirt pile from the middle of a field to the brush to clear the field for tillage in early spring. I had no problems in that mess and never had any problems in snow. I even use the tractor in our channel with 3 feet of water and a nice layer of muck on the bottom and still have never been stuck. Only experience with R-4's is on our backhoe and I have had to use the arm numerous times to get me out of a few inches of mud as the R-4's plug too easily. If you don't use the tractor on your yard any amount there is no need for R-4s.
   / Tires in the snow #8
When it came time to buy my tractor I had to answer the R1 vs R4 question. In my case, a test drive provided the answer. Tried to back an R4 equipped JD 4300 up a gentle incline with 3" of snow on top of wet grass...and the tractor didn't move. Tried the same thing with an Ag equipped 4300 and had no trouble whatsoever. But because of all the ice where I live Clementine uses Norse ice chains on the rear.
Pete
   / Tires in the snow #9
Peter, I'm very happy with my R4's. No problems in the snow, ice or loose dirt. True they gum up quick in the mud, but so far I've not been hopelessly stuck and have many hours working in 12" of muck. The R4's are also more puncture resistant than Ag's and Turf's. I brush hog at least 20 acres each summer and have not had any flats. JJT
   / Tires in the snow #10
I have R1's and plow in a high snow area. They were good but I plow in the field (paths to the pastures) and can get some pretty good piles going so I bought the duo grips chains for the rear. Can push a pretty big pile with a 7ft backblade before I start spinning.
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2014 Infiniti QX60 (A51694)
2014 Infiniti QX60...
