Tires Tires for B2150
   / Tires for B2150 #1
Milist
Mass./N,H.
B2150
I have a 1/4" hole in my rear turf tire for my B2150 4WD(calcium filled). I asked the repair facility to patch and tube. I was told that the inside of the tire has a 4" slice through the cords and that the patch/tube won't hold. Does this sound correct and if so what is the best price I can expect to pay for a replacement? or should it be a pair?
Also if I change to R4's, do I need new rims and would my front tires have to be changed as well?
   / Tires for B2150 #2
The B-2150 I used to have had Bridgestone turfs on it.
I think somewhere I still have an owners maual for a B2150.I will take a look and see what it designates.I am sure they all use different rims.at least they do on a BX2200.
   / Tires for B2150 #3
see if this works for You .It has the tire sizes that were available for the B2150 .
This is ultimately a .psf file once You Unzip it.only way I had to reduce it to a small enough file
   / Tires for B2150 #5
Milist,
If the tires have 800 hours on them I would replace at least both rears. Unless the machine has had little use in 4wd its probably a good time to replace the fronts as well. I checked my 2150 manuals and there is no mention of r4 sizes but I would guess that you would need 4 new rims. one of the newer b series tractors may use the same tire set as the 2150. if so that would give you the sizing info you'll need. Personally I would just put new turfs on. Unless you are spending most of your time on a paved surface the r4s won't do much for you.
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
71053 (A49346)
71053 (A49346)
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
