Dadnatron
Veteran Member
Purchasing a 5100e - 500hrs.
Purpose is to have a general tractor on 84ac horse farm. There is nothing other than soybeans and old fence rows at this time.
I grew up on a 4020, and quite honestly, I can't ever remember having a flat tire. We were in the sticks... and it would have had to be an odd thing in order to hit something that would go through a tire.
But now, I am on soybean/corn fields in Kentucky. I will be pulling posts and fence with an FEL mounted Intimidator. Trash trees and honeysuckle for the most part and then general cleaning up of the place. Pulling a mower as well as drilling/overseeding the fields into grass. Basically for the first couple years, I will be building the farm from the ground up.
I am debating the utility of foaming the tires. As far as general use down the road, I don't think it will be necessary. But in the 2-3 year interim, I can at least SEE some merit. However, I don't know whether it will really be worth the cost and ride roughness I hear about. I will need to add weight to the back anyway, so the weight would be a benefit. I was going to just add Rim Guard but as I began thinking, I thought about foam and never having to worry about flats again.
I will only be on dirt (or almost only) so wear and tear on tread will be slow. I don't know exactly how long tread tends to last on R1s in this type of situation. But again, I don't ever remember specifically changing a tire growing up.
RimGuard costs is $350 per rear tire.
Foam is a significant amount more.
Rear tires would add 1050 lbs per tire at a cost of $ 1450 per tire
Front tires would add 350 lbs per tire at a cost of $ 550 per tire
This is really steep... and I could pay for a lot of flat tire fixes for this cost. BUT... down time would be non-existant.
How often do you get flats? I've heard, although I have not confirmed, that you can run SLIME or a version of it, with RimGuard. Is this true?
