tired of patching my old massey hydralics
   / tired of patching my old massey hydralics #1
po boy
huntsville,texas
massey 231
well i have had this old massey 231s with a front shaft driven pump to massey 232 loder for twenty years now and for the fourth time the splines between the pump and shaft have stripped can't figure why it keeps happening but tired of repairing any solutions out there ???
   / tired of patching my old massey hydralics #2
Check mounting and releif valve psi.
   / tired of patching my old massey hydralics #3
I believe the trick is to keep the splines greased with a heavy grease about once a year. when the splines dry out the little bit of play and steel on steel is a bad situation.
   / tired of patching my old massey hydralics #4
Do you have perfect alignment? I had a similar problem on a similar model and it turned out the mounting bracket for the front mount pump was slightly off and that made the splines take up the difference. The splines would wear the teeth out until one time the pulley off of the engine broke. The Massey dealer attached a different manufacturer's bracket and no problems since.
   / tired of patching my old massey hydralics #5
Alignment, vibrating, lubrication, type coupling., whether it be solid coupling, Love Joy coupling, etc.
Can you do a belt/pulley drive for the pump? That is how the hyd for my loader works.
   / tired of patching my old massey hydralics #6
All good advice about plus don't forget to replace the opposing mating female spline....many times it is worn too and accelerates the shaft wear on the pump
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
