Security & Theft Tired of buying keys
   / Tired of buying keys #11
I don't see a private messaging area here...
You can left mouse click on someone's user name in the left hand side column, that opens a little window where one choice is "Private Message" :2cents: ;)
   / Tired of buying keys #12
On my ATV - some kind of wasp kept laying eggs in the keyhole and filling it with a wax-like substance. Finally, heated the key, jammed it thru the waxy substance and its been there for four + years.
   / Tired of buying keys #13
Buy an off-on-start toggle switch and a switch guard from your local automotive supply store and install it
   / Tired of buying keys #17
You could just install a protector around the key, my International had something resembling a cup under the nut that secures the switch, so the key is then in a recess. A shallow tin can would do the trick.
   / Tired of buying keys #18
I just used a knurled knob I had lying about and cut the key to fit.
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
1824 (A57192)
1824 (A57192)
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
