Tire / Wheel Sizes
/ Tire / Wheel Sizes #1
Texguy
Texas
Hinomoto E280
Hello group. Need some help if possible. I have a Hinomoto E280 I acquired with some different rims that came off something else.
They have 13.5x16.1 which is a 6 lug, 5.25 inside hub. Does anyone know what other tractor brands carry a similar size that would interchange. Looking for possible wheel / tire combos or take offs from a dealer to put on this Hinomoto if they would fit. Any advice in the right direction would be much appreciated.
/ Tire / Wheel Sizes #2
I don't know Hinmoto but if it's four wheel drive you need to maintain the proper ratio between front and rear outside circumference sizes. For two wheel drive it makes no difference.
It’s a two wheel drive.
The issue is the rim on there takes an uncommon size, Ive been told, therefore the rear tires are very expensive. If I could find another rim that fits and that takes a more common size tire I could cut the cost in half.
/ Tire / Wheel Sizes #4
Tires for that rim size can be expensive but compared to rims and tires possibly not.
16.1 tires not restricted to 13.5
13.5-16.1;
/ Tire / Wheel Sizes #5
What my daughter and I found on the internet was decent prices for tires (12.2 - 24) but then you have to have them shipped and then you take them and your tractor to the local tire repair shop that can handle about any type of tire changing and now you get to pay him to do the work. So, by the time we figured it out, I was better off buying through him as opposed to the other way. My tires were as old as the tractor (1982) and they were coming apart and I figured it better to do it now, then have him come to me with my tire falling apart in the field, buying his tires and them doing it in the field. It was easier to take to him and pay out the $780.00 then anything else. Went to breakfast and went back and picked it up. All done. Good Luck with your choice.
