Tire Weight
   / Tire Weight #1
Mac Matthews
Chattanooga,TN
FarmPro 2420
On my Farm Pro 2420 I bought second hand, One tire has fluid in it and the other doesn't. Can I put fluid in it myself? If so how, and what fluid.
   / Tire Weight #2
You can do it yourself. You just need the proper tools and materials.
In your neck of the woods, you will have to use ballast that won't freeze. Calcium Cloride or the "beet juice" stuff.
Down here, we can get away with plain water.
Just do a search on "tire ballast" and you should get plenty of reading.
   / Tire Weight #3
a 5-9$ burp valve from napa or a farm store, plus a garden hose will get water in..
ballast as you wish.. antifreeze mixes, winter wwf fluid.. etc.. etc..
will want a tire valve tool, and for loading the ballast, the stem of a garden sprayer usually will let you pump the raw ballast into the tire before you add water.
jack tire up to take load off.
fill to 75% level
   / Tire Weight #4
. . .will want a tire valve tool, and for loading the ballast, the stem of a garden sprayer usually will let you pump the raw ballast into the tire before you add water.
jack tire up to take load off. . .
Or, you can first deflate tire by removing valve core, attach a hose to the stem, drop the other end of the hose into the ballast container, then jack up the tractor to create a vacuum and it will suck the ballast into the tire.
   / Tire Weight #5
that don't work with tube tires.. :)
   / Tire Weight
Thanks for the info. I have tube type. I'll try TSC for the valve. I assume I acan use cheap antifreeze or windshield washer solution. Would calcium
chloride be the least expensive way to go and what ratio of dilution would i use?
   / Tire Weight #7
yep.. cacl is usually the cheapest, and same omparable weight to rimguard.
bag of mix has directions for disoloution
   / Tire Weight
Thank you again. I have learned a lot from this web site
   / Tire Weight
So am I going to have a problem filling a tube with just a adapter?
FRONTIER LR5060 LOT NUMBER 148 (A53084)
FRONTIER LR5060...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2121 (A51244)
2121 (A51244)
2013 INTERNATIONAL MA025 ROUSTABOUT (A52472)
2013 INTERNATIONAL...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
