Tire Up, down, then stall - now no start... where to look? (14 hours new owner)
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #1
PetersenRockFarm
Madison, NH
Kioti NX6010
Hello tractor folks,
New owner, 14 hours on my Kioti NX6010.
Using a tree / post puller today, all going great until I get a small stubborn tree, 'drivers' side rear tire lifts up off ground maybe a foot?, I release tree, tire and tractor come down kind of hard (not that bad in my opinion); tractor stalls out / shuts off. Now will not start, not turning over, all indicator lights a-ok. All power switches working (lights, etc)
No error codes, have power all around. Foot on brake, tried both neutral positions, checked fuses for anything obvious, none look blown (cannot tell on relays though, have multi-meter, can check if I know which one and what to look for)...
thoughts on where to look? Is there a cut off switch somewhere?
Much thanks in advance !
Erik
Petersen Rock Farm
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #3
Check all the safety switches. Maybe the seat switch?
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #4
Check the seat switch as well. Might have jarred it out of place.
thanks folks, yeah, it's gotta be something really simple - I'll look for the seat switch and double check levers in morning. I thought I checked them all a couple times, walked away for an hour and then came back to it fresh even, thinking that would help me see the obvious. No idea what the seat switch looks like, presuming it's under the seat. I'll find it and check and report back in morning. Thanks!
Erik
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #6
Good luck and welcome to the forum!
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #7
I hope you weren't using the FEL and were lifting so uneven that it pulled one rear tire off the ground. That's a good way to warp the loader.
Not that it would have anything to do with it not starting. Let us know what you find.
RSKY
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #8
I'm betting seat switch.
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #9
Is the starter relay seated in its socket and operational? I dont know about your newer tractor, but on my series of tractors, it is the first one on the left on the firewall as you look back towards the operators position. Mine doesn't have a seat safety switch. But does have a neutral Potentiometer position (2 actually) L-N-M-N-H. That pot feeds into the cruise module that throws a ground on the low side of the start relay IF the PTO is off and it reads the pot as being the correct resistance to be in Neutral. (either one).
   / Tire Up, down, then stall - now no start... where to look? (14 hours new owner) #10
Is yours hydro static? Try working the go peddle back and forth. Every time my Bobcat acts up its the go peddle safety switch.
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2009 Lexus RX 350 SUV (A50324)
2009 Lexus RX 350...
