Tire trivia of the day!
   / Tire trivia of the day! #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Ok here's a tire physics question I need help with:
My trailer tires are ST235/80R16. If it is 0 deg Fahrenheit and I inflate the tire to 80psi...
What is the pressure in the tire when the ambient temperature becomes 60 deg Fahrenheit?
Assume sea level. How about tire compliance?
   / Tire trivia of the day! #3
orezok's # seemed familiar.... went to see what tirerack listed....
"The rule of thumb is for every 10 Deg Fahrenheit change in air temperature, tire pressures will change about 2% (up with higher temperatures and down with lower). This means that light-duty, standard-pressure tires (typically inflated to 30-50 psi) used in applications on cars, vans and light trucks will change by about 1 psi; where heavy-duty, high-pressure tires (typically inflated to 80-100 psi) used in applications on recreational vehicles, busses and trucks will change by about 2 psi."
So.... looks like with an LT class, closer to 2# per 10F.
Rgds, D.
(If you like crunching #s, I'd say this falls under PV = nRT. Never looked at tires at that level, so don't know the specific coefficient to use with an LT class).
Edit - included a link for the tirerack page I got that info from, but when you click on it, they post a full page shopping ad, with a manual redirect link (for what I wanted to post) at the bottom. I'd rather not post the link - it's easy enough to search for.... D.
Great info. Yes I was headed toward ideal gas law but didn't know how to factor for the tire's compliance. :confused3:
I the 2%/10degF is probably based on actual data and probably more accurate than the 'mental gymnastics' I had in mind!
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2025 Quality Steel 6' x 14' Utility Trailer (A50515)
2025 Quality Steel...
2021 JLG SKYTRACK 10054 TELESCOPIC FORKLIFT (A51242)
2021 JLG SKYTRACK...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
