Tire trivia of the day!
   / Tire trivia of the day! #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Ok here's a tire physics question I need help with:
My trailer tires are ST235/80R16. If it is 0 deg Fahrenheit and I inflate the tire to 80psi...
What is the pressure in the tire when the ambient temperature becomes 60 deg Fahrenheit?
Assume sea level. How about tire compliance?
   / Tire trivia of the day! #3
orezok's # seemed familiar.... went to see what tirerack listed....
"The rule of thumb is for every 10 Deg Fahrenheit change in air temperature, tire pressures will change about 2% (up with higher temperatures and down with lower). This means that light-duty, standard-pressure tires (typically inflated to 30-50 psi) used in applications on cars, vans and light trucks will change by about 1 psi; where heavy-duty, high-pressure tires (typically inflated to 80-100 psi) used in applications on recreational vehicles, busses and trucks will change by about 2 psi."
So.... looks like with an LT class, closer to 2# per 10F.
Rgds, D.
(If you like crunching #s, I'd say this falls under PV = nRT. Never looked at tires at that level, so don't know the specific coefficient to use with an LT class).
Edit - included a link for the tirerack page I got that info from, but when you click on it, they post a full page shopping ad, with a manual redirect link (for what I wanted to post) at the bottom. I'd rather not post the link - it's easy enough to search for.... D.
Great info. Yes I was headed toward ideal gas law but didn't know how to factor for the tire's compliance. :confused3:
I the 2%/10degF is probably based on actual data and probably more accurate than the 'mental gymnastics' I had in mind!
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2013 Ford Taurus Sedan (A50324)
2013 Ford Taurus...
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
2015 DODGE RAM...
