Tire traction L3400 concerns
   / Tire traction L3400 concerns #11
First, the measurement is from the middle of the tread, not the outside edge.
Second, the tread width on my L4400 (similar but slightly smaller than the 5000) can range from 46.5 to 60.8 inches, a range of 14.3 inches.
   / Tire traction L3400 concerns #12
My L4400 has a rear track of 67 inches. I think if I move them out to the widest flanges could gain another 2 inches on each side; probably not a bad idea for stability in the woods or with heavy front end loader work, but I also lose work room in tight spaces plowing this winter. UHHHH, Just where was that shrub under all that snow??.....OH My . Maybe I'll leave them where they are.( N80 gave me that advice several months ago).
simonmeridew
   / Tire traction L3400 concerns #13
This may help in your decision. I have a small fleet of tractors. Two of them have R-4's, and the others are R-1's and Turf's. If traction will be the main issue, go with R-1's, which will get more power to the ground. Also, with the rear wheels being adjustable; you can choose your own comfort level for the slopes. The R-4's are "all purpose" and do have their shortcomings. In muddy conditions, the tires turn into slicks providing little traction. But on a hard surface give a smooth ride, great for loader work, and with the wider width and heavier casings may add durability and longevity, working in unknown conditions, where a "flat" maybe a factor? They will provide a more puncture resistant tire? The down side for your tractor, the cost will add $400+ to the bottom line. I use the turf tires for lawn use only. If you are leaning to R-4's; you can also add chains for additional traction. The down side to my R-1's, are the front tires being narrower, tend to look "stressed out" with a max. loaded loader bucket with max. tire inflation!
   / Tire traction L3400 concerns #14
"First, the measurement is from the middle of the tread, not the outside edge.
Second, the tread width on my L4400 (similar but slightly smaller than the 5000) can range from 46.5 to 60.8 inches, a range of 14.3 inches"
Good info N80. It sounds like Cedarweed is going to get a tire width, out to out, of over 60" when it's all said and done. I would think that this makes for a very stable unit.
   / Tire traction L3400 concerns #15
I imagine the outside width is really the most important measurement for practical purposes but when you look at the numbers in the manual they are measuring from the center of the tread.
   / Tire traction L3400 concerns #16
Congratulations on choosing an L3400! I'm continue to be impressed with mine after 2 years of abuse.
Being used to R1's on 2-wheel drive machines, I was quite UNimpressed with my initial use of the R4's on my 4x4 in some slushy spring weather in the bush.
Now that I'm loaded (tires that is) and using chains in the winter, I'm quite impressed with both traction and stability. I think loaded tires will make the most difference for your stability regardless of wheel position, IMHO.
The R4's are tough, great on the lawn, and seem more suited to significant loader work? Having said that, if traction is a top priority, there is no argument that R1's will really tear things up for you.
Shawn
The L3400 we ordered was delivered today, just early enough for an hours ride around and about this place before dark. Love it. I wish to thank everyone who helped me in deciding which tires (chose loaded ags) and in learning about the full range of tire widths available. That info, by the way, was the deal maker in deciding on the L3400. The dealer made the left/right switch as well as moving the wheel to the outside of the flanges. For the present, at least, that is just fine for me. Chose the ags because it will not be a lawn tractor and will do considerably work in the woods during the winter rainy season and with a lot of clay, traction is an issue. All in all, the process has been a lot of fun and I've learned quite a bit of good information. I have the fine folks of this great forum to thank for that and do so with sincerity. Time now to get my nose into the manuals.
Best regards,
Cedarweed
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
PAIR OF 5' PIN ON FOLD UP RAMPS (A54756)
PAIR OF 5' PIN ON...
2015 Volvo VNL 64T (A55218)
2015 Volvo VNL 64T...
BUNDLE OF 22" X 60" EXPANDED METAL (A54756)
BUNDLE OF 22" X...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LDH-HT380 STAND ON SKID STEER (A54756)
UNUSED LANDHONOR...
