Tire Spinning on Wheel!
   / Tire Spinning on Wheel! #1
Dr Dirt
Lebanon Maine
New Holland td 24
I thought that I should share this one!
As most of the country went into a deep freeze I went to move some round bales and proceeded about 50 feet when the tractor bogged down and only the 4WD front tires were spinning. This machine is HST and when I set it to 2WD the rear axle was kind of surging similar to a really badly slipping clutch. This made no sense whatsoever until I discovered that when I first moved the tractor the LR tire was frozen in solid ice and the torque actually broke the bead from the wheel rim and the tire! The temp was so cold that the "flat" calcium filled tire never lost it"s shape and by luck I noticed the wheel spinning with the tire remaining still. PHEW! Just thought this was worth sharing.
   / Tire Spinning on Wheel! #2
Now that's cold.
Now that's cold.
Thomas , I notice that you are also from Lebanon ME! Thankfully it was just a slipped bead and Central tire remounted and re filled for $80, not bad. The spare was also packed in ice and with no FEL to dig it out that was actually the biggest problem. I solved it with a come-along and a nearby tree! I needed to put the torpedo heater near the spare to help melt the compacted ice on the rim and BTW the compressor needed a shot of hot air before it started too! This was a few weeks ago when it was REALLY cold!
2014 INTERNATIONAL MA025 BOX TRUCK (A52576)
2014 INTERNATIONAL...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2013 FORD F650 ROUSTABOUT (A52472)
2013 FORD F650...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
