Tire slow leak
   / Tire slow leak #1
amorey
Kubota BX24
I,ve got a small tear in my front tire of my BX 24, the tire is fairly new so I don't want to replace it. Should I go with a tube or is there a repair kit I could use? The tire goes flat in about 7days.
   / Tire slow leak #2
On the inside of the tire, put a patch, then a new tube, and your ready to go.
   / Tire slow leak #3
If its a tubeless tire like mine is, I use a can of fix a flat. Then fill the tire to full air pressure. It lasts a long time and is water soluble for easy cleanup when it does require a tire dismount to permanently patch and fix or replace the tire.
   / Tire slow leak #4
I bought new 6 ply tires a few years ago. One got a slow leak last year...I found a cut in the sidewall, not through to the cords but when sprayed with soapy water little bubbles appeared. Air found it's way through the plies. I put a tube in it.
John
   / Tire slow leak #5
If patch would be easy than yes,but I would also tube it..double protection,for it always seems blow out happens the farthest point.
   / Tire slow leak #6
On my l245 I got a tear where a branch tried to tear a hole in the side wall. I put a tube in it and it is still running great after years of service!:)
   / Tire slow leak #7
A few weeks ago TSC had big cans of Slime instant tire repair on sale for $5. I bought a can and used it to repair (6) leaking small tires Saturday: (1) on my logsplitter, (3) fronts on (2) different riding lawn mowers, and (2) on a small generator. I think most of these were rim leaks but at least one, on a mower, was a similar side-wall leak. All those repairs took me a total of 1/2 hour and it appears they are all holding. It all depends on how much you value your time and money I suppose when it comes to how you go about the repair. A tube and patch may be a better long-term solution but would undoubtably take a lot more time and money. I would go for the fix in a can first.
   / Tire slow leak
Tire slime fixed it, also put some shoe goo over the gash, the stuff is amazing the heal rubber on rubber, dries hard too.
   / Tire slow leak #9
best way to fix it with out a new tire is patch the inside of the tire and tube it. next best thing if its in the tread is a tire plug, slim and fix a flat are hit and miss when i have used them.
   / Tire slow leak #10
yep.. I only like slime and fix a flatr for porous rubber.. not actual holes.
soundguy
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
WIGGINS 5K FORKLIFT (A52472)
WIGGINS 5K...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
2015 MACK CXU613 (A52472)
2015 MACK CXU613...
