Tire Slime
   / Tire Slime #1
Richard
Elite Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Is tire slime still being recommended?
Went out to cut some fields yesterday, front tire flat as a pancake. Found a thorn, pulled out & filled with air and off to cut. Got the field cut with slow leak but took initial fillup with air and two more trips back to house.
Taking tire to co-op tomorrow to get "fixed" and thought of the slime stuff.
Does it work that well and can I put it in AFTER the fact?
This is a 3 ribbed tire with some dry rotting. Rather not put tire on if I don't need to and hate idea of tube with known thorn in rubber (my luck is where there is one, there is usually 100)
Thoughts on slime?
   / Tire Slime #2
It would probably work. You jack up the tire, put it in with the valve on top, spin it around a bit, inflate it, and drive it and check it.
Mike
   / Tire Slime #3
Richard,
I have thorny Honey Locust all over. After fixing more flats that I care to remember I started using Slime. I have it in the lawn mower tires, ATVs tires, dirt bike tires, front tractor tires (3-rib), Toolcat tires, disc tires ......
I've been told numerous times it is a mess when you do have to change one with it in but in the mean time I don't worry about flats. I still see plenty of thorns sticking out of the tires but now I just snip them off with side cutters.
dsb
   / Tire Slime #4
I bought a gallon of Slime and then was reluctant to put it in because my neighbor said it could make a tire lumpy. Any truth to that?
   / Tire Slime #5
I doubt it. I recently put slime in the front tire of our riding mower to fix a slow leak on a lightly used tire. It worked great - tire holds air, and no apparent lump, wobble, or any other problem with it. FYI, though, they recommend 16-24 oz on a riding mower tire. The quantity for a tractor tire is probably huge.
   / Tire Slime #6
I seriously doubt it considering the stuff is supposedly safe for high speed passenger tires.
FWIW, considering the thorny mesquites I have all over my property, I use the stuff in all my equipment tires (even my wheel barrow) with unbelieveable success.
   / Tire Slime #7
Except for a slight mess when changing out an old tubeless for a new tubeless tire where Slime had been used I have never seen or heard of a factual report of a downside. If you ask around you might hear all sorts of BS stories about nearly anything but try to find the guy who actually had the personal experience!
You want to have the valve stem somewhere else besides the 6 O'clock position when you gauge the tire pressure so you don't get slime in the Schrader valve and in your gauge. When you install slime you remove the valve core so it isn't a problem.
SLIME is good!!! I have thorns aplenty and haven't added air to my tractor tires in over 3 years. Great stuff for all pneumatic tire applications, tubed or tubeless if you are subject to nuisance leaks. Slime will not cure a tire that has had a big stick rammed through the sidewall. I use it in everything that goes out in the pastures off road.
Pat
   / Tire Slime #8
First, my view is scewed, I sell the pink stuff. :)
For years and years I have used the green Slime tire sealant. I recently went to a meeting in Ft. Worth where they went over the differences between Slime and the TireSeal. They said if I had any tires that had had Slime in them for a long time I should dismount one and see what it looked like in the tire. So, being curious I got home and dismounted a lawn mower tire that I know has had Slime in it for at least 8 years. Yikes! All of the fibers were stuck in a rusted mass to the rim and there was this yucky stinky brown liquid left.
Next they said to put some TireSeal on a piece of glass and also some Slime and let them dry for a day. This demonstrates the difference when they dry with the TireSeal being much more "rubbery". Yep, it was. I then stuck those little sheets in the electric tape cans in the picture in my sample case in the trunk of my car. By the end of the day in the heat the TireSeal had turned the pictured blue color and is leaching some type of liquid, something I had not expected.
Let's just say I have spent the last 2 day's dismounting about 26 tires, cleaning rims and refilling with TireSeal.
Interesting side note and something I didn't know. TRC's TireSeal is the first and original tire sealant. They came out with it in 1965.
Click images for larger picture.
   / Tire Slime #9
   / Tire Slime #10
The quantity depends on the product. With TireSeal the 14.9 x 28 takes 10 pints or 160 ounces and the 9.5 x 16 takes 4 pints or 64 ounces. Check the product container of whatever you use to see what the fill ratio is.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
Sims Snow Board (A51573)
Sims Snow Board...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
