Tire sizes
   / Tire sizes #1
JD 1250
Milton, Tn
John Deere 1250
I have a John Deere 1250 that has 14.9-28 tires on it. My question is, can I put 16.9-28 tires on the same rims that the 14.9-28 tires are on? Thanks for your help.
   / Tire sizes #2
You might be able to put them on, But they probably would not have full tread connect.
14.9 should be on a 12 or 13 inch wide wheel. I am guessing you 12 inch wide wheels.
16.9 should be on a 15 or 14 inch wheel. 15 inch wide prefered
   / Tire sizes #3
Also if you have mfwd, the 16.9s will be taller and throw off your front to rear tire ratio.
   / Tire sizes #4
FWIW - My Kubota M6040 runs R-1 Firestone on the rear. They are 16.9 x 28 - - mounted on Titan 28 x 15 steel rims.
For sure - if your tractor is MFWD(4 WD) - then going from 14.9-28 to 16.9-28 WILL create problems with the MFWD system.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2002 Ford F-350 Flatbed Truck (A51691)
2002 Ford F-350...
2010 VANGUARD 53x102 DRY VAN (A53426)
2010 VANGUARD...
Valvoline 80/90 Gear Oil (A53117)
Valvoline 80/90...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
