Tires Tire sealant - with tubes?
   / Tire sealant - with tubes? #21
Shortly after I got my B7610 back from the dealer for my backhoe install in 2009 the rear tires leaked down and I slimed them at the minimum rate. Several times since then I've noticed a LITTLE slime leakage but not much, and they still hold air well.
   / Tire sealant - with tubes? #22
I stuck a stick thru one of my front tires on my M9000. It was about 3/8 inch or so. I really had my doubts if slime would handle a hole that big. I pumped it in and moved the tractor so the hole was on the bottom and let it sit for a few minutes. It leaked out about a spoon full and has never leaked again. Slime is wonderful stuff.
   / Tire sealant - with tubes? #23
So anyone with experience with slime, how much of a mess is it? Say if you get a hole that needs to be patched? What if you want to change tires, how much of a mess does it make of the rims?
   / Tire sealant - with tubes? #24
Last time I changed tires on my 4 wheelers it wasn't that bad. I guess if you have a gallon or more now it might get messy. Did nothing to my wheels that I could see. I have yet to see a real down side to using slime.
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
UNUSED AGT SKID STEER QUICK ATTACH SEEDERDRILL (A51244)
UNUSED AGT SKID...
2010 Ford F-150 (A50323)
2010 Ford F-150...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
