Tire replacment, best to replace both on MFWD?
   / Tire replacment, best to replace both on MFWD? #1
JasG
CNY
B2650,
I have a friend that had to replace 1 front tire on his tractor that is MFWD. The tractor has over 4000 hours and the front tires were about 60% worn. I have read several times over the years that on driven axles of tractors and other similar machines if the circumference difference is greater than 5% then both should be replaced. I've been looking but I can not find such information now. What I keep finding if about the difference between front and back tires on 4wd tractors.
Does anyone have similar information or a link I can show him. He asked my opinion and would like to see it for himself. If he only use the tractor around the farm I would say even then he would be OK. This year though he started using the tractor to deliver hay and it's an hour each way on paved roads. I don't think it's a good thing for his front axle being that it's limited slip.
   / Tire replacment, best to replace both on MFWD? #2
Won't matter as long as he kicks it into 2wd on hard surfaces.
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
1831 (A51247)
1831 (A51247)
Landoll Hauloll (A53473)
Landoll Hauloll...
Skid steer auger plate (A50322)
Skid steer auger...
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
