tire removal
/ tire removal #1
rangerrick180
griffin ga.
ym 180
hy folks,
i have got to replace one of my rear turf tires on my ym180,
on the rime there is a pin going thru the axle and also two bolts
with springs on them. then what appears to be regular lug studs or nuts behind them.
what all has to be removed take rim off?
thanks in advance any info will be appreciated.
/ tire removal #3
You need to remove the pin and the bolts to separate the rim from the hub. And the hub can slide right off the end of the axle after those clamp-bolts are loosened.
You might be lucky and have enough clearance to slip the wheel over one remaining clamp bolt after removing one.
Question for anyone: does anyone run the hubs flat side out and the wheels outboard of that? This gives maximum width for stability. But there's no shoulder on the flat face of the hub to center the wheel, so only the lug nuts are centering it. I'm trying this on the second YM186D that I'm still tinkering around setting up. I put the hubs on the belt sander and confirmed they were ground flat on that outer face. But I wonder if Yanmar intended them to be run this way.
/ tire removal #4
Hubs flat side out-- that's the way mine was set up when i bought it. The tires hang out well past the fenders (just like back in high school).
I haven't had any problem with it that way.
/ tire removal #5
Mine were mounted outboard as far as possible and my hub hex is worn enough that the wheels wobble. I now have them inboard so they just clear the fenders
and are better for my 40" tiller on a YM-187d. New hubs have .040" clearance on the axle so I have not bought any. Do you agree that that is excessive on new hubs?
Many tire installers prefer the wheels be on the tractor for tire install.
N Michigan
/ tire removal #6
hex is worn enough that the wheels wobble. ... New hubs have .040" clearance on the axle so I have not bought any. Do you agree that that is excessive on new hubs?
Maybe reduce slop by slipping in some .030 shim stock on the side opposite the jam bolts??
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
Single Cedar Glider (A65583)
Single Cedar...
(2) New 14-17.5 NHS tires w/ fluid on 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
