Tire Pressures
/ Tire Pressures #1
chopped
New England yankeee
Maybe a bit off key here , but I understand why they don't have a tire pressure printed on tractor tires. We all seem to run them different pressure due to uses.
Ive been mounting tires since the 70's. And now with all the hoopty about the sensors for tire pressure, I wonder why the air pressure is still printed so small. I myself use glasses but when I have to use glasses and a magnifier I wondered wy they dont have the number bigger.
We are supposed to be more concience of this nowadays.
Is it just me or is this common sence if you wanted to keep them aired up? usually just go with 40 even..with no problems with wearing
/ Tire Pressures #2
On some of the cars and trucks I have seen, the "recommended tire pressure" is listed on the door sticker along with all the other info now posted there.
My tractor tires have the psi printed on them. (a 2005 model)
/ Tire Pressures #3
Printed so small? Well, I agree; small for me anyway. But since I started working on tires in 1956 and didn't have any trouble reading the tire pressures in years past, I thought it was just my age and deteriorating eyesight.:laughing: In fact, I just recently bought myself a Great Point Lighted Magnifier.:rolleyes:
/ Tire Pressures #4
And plus all the above we need to sometimes adjust for the tire condition too. This one actually has air pressure above atmospheric and the trailer it was on was pulled to the auction.
I couldn't see the numbers and I couldn't hear the leak if it had one. And if I were told on TV some idiot would be beating on a 55 gallon drum in the background so I couldn't hear. Come on society, cut us old folks a little slack.:laughing:
/ Tire Pressures #5
The pressure listed on the sidewall of a tire is the max. pressure at the full load rating of that tire. Lets say it says 40 psi cold and the rating is 1750 lbs. Assuming your vehicle has 4 wheels/tires this means that at 40 psi those 4 tires will safely carry a vehicle that weighs 7000 lbs. and the sidewalls will be flexed properly and the tread surface will be in proper contact with the road and sheds heat, water etc.
Now what if your vehicle only weighs 3500 lbs ? They use that size/rating of tire on many,many different weight vehicles. Those sidewalls are going to be too hard and tall, and the tread surface is going to be more convex to the road instead of say flat and the tires are going to ride pretty hard and wear the center of the treads out faster than the edges of the tires. The DOT requires automakers to list what air pressure will give the proper stance etc. for the tires that they use on that particular vehicle - that's what that decal is for and that's what air pressure is ideal for that size/rating of tire that came on the vehicle. One guy's similar Chevy truck may have 500 lbs more weight than the next guy's because of certain options it has and might have a different air pressure listed. Now when you change size/style/rating of tire from the original, that decal may not apply anymore and you have to figure it out some other way. With a tractor tire you simply look at your bar contact pattern for proper stance and/or your specific needs. The air pressure on the sidewall is still a max pressure at rated load for that tire, not necessarily the tractor & tire combo you have.
/ Tire Pressures #6
skipmarcy - Thanks for that explanation. It helps.
/ Tire Pressures #7
My complaint is that I carry heavy loads and tow a trailer often. Every time our truck is serviced, we get it back with 20# in the tires.:( All it takes is a cold day to trigger the pressure alarm.:confused2:
/ Tire Pressures #9
Ive been mounting tires since the 70's. And now with all the hoopty about the sensors for tire pressure, I wonder why the air pressure is still printed so small.[/I]
people like you will use whatever device is needed to magnify the small print so they can read it. the person driving their 6000lb crackerbox-on-wheels at 80mph from the mall to the soccer game couldn't be bothered to check their own air pressure if the world was coming to an end - hence the birth of the pressure sensors. i guess the manufacturers figured it would be a waste of time to change the size of the print anyways.
/ Tire Pressures #10
I've been tempted to print the recommended tire pressure on the fender above each wheel. ... like the Army did. It seems that with several pieces of equipment, I sometimes forget which is which.:confused2:
/ Tire Pressures #11
I run 35 lbs in my 4:50-21 Model A tires ;-)
40 lbs if you have a Woody from 1929...
No kidding... I have a old model A with 16 inch rims and military tires... haven't put air in them since I hauled it home in 1991... why is it some tires, in this case with tubes, never loose air?
Have no fear if you have your car serviced in California... it is now law that tire pressure be checked and records kept for 3 years...
I think I will start a new Thread for anyone interested.
/ Tire Pressures #12
It hink it would start something new!!! It might also change the past as Firestone might not havehad a large lawsuit from people driving faster then the soft tires would allow on their Ford explorer!
You should check your tires to be sure that they have a full foot print on the ground. That is the the best way to check for proper pressure.
/ Tire Pressures
Have no fear if you have your car serviced in California... it is now law that tire pressure be checked and records kept for 3 years... I think I will start a new Thread for anyone interested.[/QUOTE said:
I yield my Thread to this...new subject...
/ Tire Pressures #14
I wonder if someone is trying to put the responsibility for low tire pressure related accidents on the service companies?
/ Tire Pressures #15
Liability is a real possibility... on the other hand, it is as if the consumer is viewed as too inept to even check tire pressure...
I always try to do right... these days, I'm sure there are laws I don't even know about...
The gist if the new law is curbing Green House Gas by improving fuel efficiency.
/ Tire Pressures #16
That was kind of my thought....
The consumer (vehicle owner) being too lazy or inept to check their tire pressure and feeling accidents are not their fault because they had the vehicle serviced.
IMO, it is the driver's resposibility to ensure that the vehicle is road worthy. Here in Washington, the driver of a comercial vehicle is responsible for checking the condition of the vehicle before taking it on the roadway. If it has inoperable lights, bald tires, or an unsecure load, it is the driver who gets the ticket.
I feel that it is the same with a personal vehicle. The driver is, or should be, responsible to ensure that the vehicle is in a safe operating condition before getting in and driving the vehicle. How many drivers never check their tire pressure or lights/turn signals the entire time they own a vehicle? Many, I'm sure.
/ Tire Pressures #17
My Grandfather always told me to take a look around the car before blindly getting in a driving off... out of habit, I do.
I confess I no longer check the oil with every fill-up... my daily driver goes 7500 miles per oil changed and is almost on the mark... manufacturer says 15000 miles between changes.
Generally, every Saturday each vehicle gets an under-hood and tire check... and always before any distance trips... like making a run from Oakland to Olympia ;-)
When I worked at the car lot... part of my job was to make sure each used car had a property inflated tire with the necessary tools to change a flat. Most of the spares were woefully under-inflated and often tools were missing... someone wasn't checking.
/ Tire Pressures #18
I check things less frequently on my every day driver and always do a full check before a trip, but I believe that you and I are exceptions any more. I wonder if they still teach that in driver's Ed?
/ Tire Pressures
No longer does' keep an eye on the tire 'mean anything.I had a christmas visitor come last week in a van My son see's that one tire looks soft. turns out it hade 11 lbs in it. all the others were low also..The driver just shrugged it off. oh??? I simply dont understand it.Maybe im over zealious in keeping them up because im the one mouting them all.
Some people still cant pump their own gass either.. but they pay more for it ....
/ Tire Pressures #20
Just think in 3 years all cars will have to have a rear view camera. I would say two or three years after the Gov will say that each tire pressure will need to be displayed on the rear view camera screen.
Gas Oven (A60352)
Gas Oven (A60352)
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2025 80in Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
2017 Ford F-550 Signalier ATR 45ft Bucket Truck (A61568)
2017 Ford F-550...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A60736)
2019 INTERNATIONAL...
