Tire Pressure
   / Tire Pressure #11
TVMAN - You know - my Kubota M6040 doesn't ride as good as my Jeep - out on the asphalt - either. AH - maybe it might be because the Jeep is designed for highway use with suspension - my tractor is designed for dirt - no suspension - FEL with 820# grapple hanging out front - 1100# Rhino rear blade on the 3-point.
I have no desire to preach to you on how your tractor should or should not ride - but come on Man - its a tractor. Besides it appears you have shod it with R-1 tires. If you wanted a smoother ride - go with R-4 tires.
Yeah - tires are expensive. You did well to find Titan at half price - - they are a top of the line tire.
Now - get off that asphalt and get out in the dirt - and have a great day.
   / Tire Pressure #12
A bias ply tire will develop a slight flat depression when they are in static position for any duration. When driven immediately afterword on a hard surface, the tire will lobe, out of round until the friction warms the tire and it resumes a round uniformity.
Radials do not suffer the same condition but they are more expensive and uncommon on compacts and light utility tractors. Radial shoes are more common w/ AG R-1's but many construction TLB tractors , R-4, are equipped w/ radial tires.
   / Tire Pressure #13
R4s have heavy side walls and will ride rough. If you have a loader, for the fronts, inflate to the maximum marked on the side of the tire. Rears you will have to experiment with, One way is inflate to maximum marked on the tire then chalk a couple lugs and drive on a hard surface. Deflate and test drive until chalk wears off all the way across.
+1............ Pressure in the front keeps the sidewalls rigid, needed for FEL work. The opposite is needed for rears. There are a couple of rules of thumb: Let the air out till the edges of the tire contact a hard surface; concrete floor..........let the air out to a level that will allow you to carry your max 3 pt load with slight sidewall bulging.
On fronts with a FEL I use the max press on the sidewall of the tire. On non FEL tractors 20 or so......just enough to keep the sidewall (outer tire) somewhat rigid in turns without brake assisting. On rears, 15 psig on the right of the tractor with a side mounting mower (disc/drum type hay cutter), other side 13. All other tractors 13, including ones hauling 1000# bales on the 3 pt. After that time to attack the seat. You won't believe what time and money I've spent on seats and such to get a smooth ride.....but I think I'm finally there.
   / Tire Pressure #14
And then there is this OTHER factor - age. As I get older I seem to be less tolerant - I want things a tad softer, smoother, easier, quieter.
The nice thing is - retirement allows for most all of those "wants". Its taken quite a while but I HAVE learned to slow down a bit.
Softer tires DO give a smoother ride...........
   / Tire Pressure #15
Tractor tire pressure has a bit but not much influence on ride on a tractor. Since there is absolutely no suspension give, and you are limited in the amount of air pressure that you can run due to load and sidewall deflection in turns on the front, the best money you can spend to make a smoother ride is getting a suspension seat.
Don't waste money on new tires because they are going to be pretty much the same ride regardless of the tire type. The better the seat, the smoother the ride with air suspension being the top of the line.
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
Ford 4630 (A53317)
Ford 4630 (A53317)
2015 CATERPILLAR 323 FL EXCAVATOR (A52707)
2015 CATERPILLAR...
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
