Tire pressure
/ Tire pressure #1
RPott
Waddell, AZ
Branson 3515H
This may seem like a stupid question, but I'm looking at tire pressure settings in the Branson manual and don't know what to make of this (see pic). I grew up on PSI. image.jpeg
/ Tire pressure #2
Pressure PSI and Metric
Bruce
/ Tire pressure #3
It is a good idea to look at the pressure rating written on your specific tires. My rear tires have a limit of 20 psi, which is below what your manual says. I looked in my manual, it doesn't list any tire pressures.
/ Tire pressure #4
Also, it has a lot to do with how you will use the tractor.
Example - I have either a bucket or grapple on my FEL. I keep the front tires pumped up fairly high so I don't roll them off the rim with a heavy load - around 35psi.
The sidewalls say I can got up to 40 psi.
- the rear tires, I run at 18 psi - so the chevrons/bars make full contact on a hard surface.
/ Tire pressure #5
I always try to adjust based on contact patch when loaded
/ Tire pressure #6
Me too. Since ride is usually rough, I do everything I can to smooth it out. TP definitely is in the equation. On manual value vs max tire pressure, you need to do as Cougs fan mentioned and look on the tire sidewall since a lot of tractors can run R-1 thru R-4s and the pressures are different....i'd assume since the tire structure is different.
/ Tire pressure
Thanks for the replies. Good info to know.
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP73V67X124782 (A61165)
2007 Ford Crown...
2001 Freightliner MB55 Bus (A61568)
2001 Freightliner...
John Deere 1025R (A62177)
John Deere 1025R...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVER (A62131)
UNUSED WOLVERINE...
KUBOTA M9000 TRACTOR (A62130)
KUBOTA M9000...
