Tires Tire pressure?
   / Tire pressure? #1
TomOfTarsus
North of Pittsburgh near Airport
1999 New Holland TC18 HST
I'm risking looking like a complete dunderhead here, but...
I can't find recommended tire pressures for the R4's on my little TC-18. It has the R4's on it, and nothing is stamped on them or stated in the manual. I haven't read the manual word-for-word, but checked the spec sections and stuff where I thought it should be...
In other news I was wildly successful in backing the tractor out of the garage last night and turning it around, backing back into the garage! Woo-hoo! :rolleyes: Well, at least now if we get that big snow, the FEL is pointed out! I got 10 whole minute's seat time now! Yee-hah! ;)
Thanks, all!
   / Tire pressure? #2
Tom
My manual states 26.1-37.7 psi front, 26.1-37.7 psi rear.
Solo
   / Tire pressure? #4
Tom
Look on page 2-28 in the owners manual.
Solo
   / Tire pressure? #6
I found my traction improved when I ran my rears a bit soft with 15 psi or so. I don't know if that is an acceptable pressure or not but it works well on my little tractor.
John
   / Tire pressure? #7
It's common to underinflate tires for a bit more bite.. just as long as you are not ruining the side wall, have enough pressure for the load on the tractor, or ar not risking spinning the tires on the rim.. etc..
soundguy
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
John Deere 3038E (A50120)
John Deere 3038E...
