Tire pressure with FEL?
   / Tire pressure with FEL? #1
millers1
Eastern - West Virginia
Deere 2210, X320
I'm working on clearing brush with my new ratchet-rake attachement for my trusty 2210. Should picked up the ratchet rake a long time ago! Running with the FEL and ballast box, what is the general conscensus on tire pressure? I know opinions will vary but what are would you run with this application. FWIW.. this tractor is not used for mowing.. just FEL work around the yard.
   / Tire pressure with FEL? #2
with any kind of FEL load, I would prefer to keep max pressure in the front tires, per the tire sidewall. Do you have r4's on the front?
I'd have to look.. they're next aggressive tread up from turf tires. Stockers that came on it.
   / Tire pressure with FEL? #4
I have R4s and a loader. All four tires are filled to 70% with RimGuard, then topped up with air to 45psi front, 20psi rear.
//greg//
   / Tire pressure with FEL? #5
My Kubota manual says max psi (as printed on tire sidewall).
   / Tire pressure with FEL? #6
Just looked at my 300cx manual. It says 4psi over front tire max pressure on sidewall.
   / Tire pressure with FEL? #7
I run my fronts at or about the max pressure listed on the sidewall. Never had any problems with them that way.
   / Tire pressure with FEL? #8
I always forget to air up my front tires, until I have an awkward load hanging on a chain from the bucket, and smash down one tire, and the tractor begins to awkwardly tilt.
I should remember to air them up a couple of times a year.
   / Tire pressure with FEL? #9
When not doing FEL work, should the tire pressure be brought down at all? If you are mowing with R4s, is there an ideal pressure to reduce turf impact?
   / Tire pressure with FEL? #10
If the FEL is on keep your pressures high
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
