Tire Pressure Gauge for Calcium Filled Tires
   / Tire Pressure Gauge for Calcium Filled Tires #1
vinicius zidal
Streamlined look
Is there a tire gauge available? That can be used with calcium filled tractor tires and lasts for more than a few uses.
   / Tire Pressure Gauge for Calcium Filled Tires #2
   / Tire Pressure Gauge for Calcium Filled Tires #3
I've been using this one from Milton for over 20 years on my calcium filled tires.
It's supposed to be corrosion proof but I rinse it off after use just in case.
Or cheaper on Amazon:
https://www.amazon.com/Milton-S-928-Water-Filled-Pencil-Pressure/dp/B0000AXBXW/ref=mp_s_a_1_4?crid=1EY7M3S8F2HOR&keywords=Milton+Tractor+Tire+Gauge+—+For+Fluid+Filled+Tires%2C+5–50+PSI%2C+Model%23+S-92&qid=1642481301&sprefix=milton+tractor+tire+gauge+for+fluid+filled+tires%2C+5+50+psi%2C+model+s-92%2Caps%2C297&sr=8-4
   / Tire Pressure Gauge for Calcium Filled Tires #4
When the tire guy came out to put fluid in my tires, he added air to the correct inflation.
I asked how to check the pressure,
He recommended measuring from the ground to the top of the wheel, with the tractor level.
I did that, and wrote the measurement on the wall in the shed.
Now, to check the pressure, I simply use a tape measure.
The "stem" does not even need to be rotated to the top,,, (y)
You will find a tape measure is more accurate than any pressure gauge,,
the tire changes height a lot when air is added.
   / Tire Pressure Gauge for Calcium Filled Tires #5
Interesting
   / Tire Pressure Gauge for Calcium Filled Tires #6
Interesting
My first ATV (1984) did not specify tire pressure, because it was only 2psi,
Instead, the manual gave a circumference of the tire.
You had to measure all the way around the tire to get the correct pressure.
Just a little air could change the circumference by three inches.
I got a VERY low pressure gauge, and measured those tires,,
that was easier, but, less accurate than the tape measure.
I lived with that,
I did not go on long rides, where the locked axle needed to have identical tires to be able to go straight.
   / Tire Pressure Gauge for Calcium Filled Tires #7
Harbor Freight air gauge. Best ever. The long line from tire to gauge can be easily purged between measurements.
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
