Tires Tire pressure for rice tires?
   / Tire pressure for rice tires? #1
rbeitz
PA
Yanmar 1500D
I have a 1500D with the original rice tires. I can not find any tire pressure numbers on the tires themselves. Can anyone recommend what pressure the front and rear tires should be running?
Thanks!
   / Tire pressure for rice tires? #2
The YM169d book (for my 1401d) says rear tires (8-16 size) should be 23 psi max. Your 1500 might have 18" rear tires, but this might be close. Front tires (6-12) is 18 psi max.
Jim
Anybody else have a 1500d that can answer? Or should I run them with 23 rear and 18 front as jwjimbo does in his 1401d?
   / Tire pressure for rice tires? #4
You want to run them with enough pressure to keep from spinning the wheels in the tire. 15PSI and up should keep you from doing that. From there it really depends on the load you putting on the back. If they are sagging they need more. If when your driving around you don’t see the full tread profile on the ground you have to much pressure.
   / Tire pressure for rice tires? #5
One thing I forgot to mention: Like Buck said, it depends on the load. All my tractors have a front end loaders. I have tubes in the front tires and with the loader, I kick them up to 28 psi. This makes it more stable and easier to steer with a load. I had one I bought that when I checked, it came with 55 psi in the front tires! You bet I bled that down real quick!
Jim
   / Tire pressure for rice tires? #6
I have a 1500D with rice tires. The pressure is on the tire but the units are kilopascal (kpa) a metric unit of pressure. This converts to somewhere around 20 psi.
Larry
   / Tire pressure for rice tires? #7
A good approximation, 100 kpa = 15psi (close enough for tire pressure anyway - but for the purist 101.325 kpa = 14.6960 psi).
   / Tire pressure for rice tires? #8
If anyone is interested, I have a small computer program that will convert almost anything, including: power, torque and pressure, to and from metric.
I couldn't attach it because it was too large for TBN, but if anyone wants it, email me and I will send it to you.
   / Tire pressure for rice tires? #9
Yeah,
I've got it as well. Called convert.exe, 586k. Where do you think I got that conversion?
   / Tire pressure for rice tires? #10
please advise cost of program and your mailing address.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
LOT NUMBER 146 (A53084)
LOT NUMBER 146...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
