Tire pressure for R4 2910/B3030
   / Tire pressure for R4 2910/B3030 #1
Barnboy
Decatur IL
Kubota B3030
The front tires are marked 35psi max, rear tires marked 20psi. I filled the front tires to 30psi and the rear to 20psi. Just curious if its ok to fill the front tires to 35psi with a loader.
   / Tire pressure for R4 2910/B3030 #2
Seems like you have answered your own question. If the front tires are marked for a maximum of 35psi then that should be OK. Better to have too much air in a tire than too little. Especially with a FEL.
Yeah I looked in the owners manual. Should have looked there first. 35 psi front and 20 psi rear. They must have been low for a while. They were at 20psi when I checked them.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
