J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,973
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
If you should mix tires from different manufactures, be aware of the weight caring capability and the ply and air pressure.
If you want your tires to roll equally, all the tires should have the same circumference, and if you put 10 psi in some and 20 psi in others, it will not be the same. With hyd driven wheels it may not a big concern, but in a gear type setup, all the tires should be the same.
One should also consider that when working with a full load in the bucket, you are adding the weight of the bucket and load, and all the linkage in front of the front wheels and tires. For the 425, that would be about 800 lbs for load, plus 200 lbs for the bucket and linkage.
