Tire plug question.
   / Tire plug question. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
My son was over for dinner yesterday and had a flat tire when he went to leave. I was pretty sure I had a tire plug kit I bought years ago and finally found it. I’ve never used one before. It was very difficult to get the plug in, not impossible but almost. We ran the reamer in and out about 50 times and it finally went in. I assume it’s suppose be a tight fit. Is this normal? Any tricks?
   / Tire plug question. #2
Kind of normal. I normally put a small amount of tire glue on the end of the insertion tool to act as lube. But the sticky plug wants to stick to the tire when inserted, So a slow steady push works better than a quick insertion. And then when the end of the tool goes through the tire then wants to move all at once, and have to be careful to not overinsert it.
That helps. The kit came with glue but didn’t have any instructions. The video we watched didn’t show using any glue but it makes sense that would help.
   / Tire plug question. #4
I've used tire plugs for many years, often needed when I worked on construction sites. And for my wife who drives a lot of miles. My kits never had glue, they did have some very sticky rope and a lube needed to put the plug in. Todays radial tires offer a real challenge getting the probe through the many layers of steel belts. All my efforts to plug tire punctures have been successful.
   / Tire plug question. #5
I also have successfully plugged tires over the years with, or without the glue... Didn't make any difference. Sometimes I've had to ream the hole out maybe a dozen times, and rotating the tool seems to help.
   / Tire plug question. #6
I even used a drill on one. 🤬 :ROFLMAO:
   / Tire plug question. #7
I've always just used a drill.
   / Tire plug question. #8
Basically they supply what looks like dielectric grease. Or silicone grease.
   / Tire plug question. #9
it's rubber cement like the old school paper glue, not sure of it's composition but it does glue rubber...
   / Tire plug question. #10
Some come with rubber cement like you discuss. But some come with silicone grease in a small pouch. Or the bigger kits have a small container looks like a Skoal can with lube.
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
Portable Airtank (A57454)
Portable Airtank...
Kubota GR2100 Riding Mower (A57453)
Kubota GR2100...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
MASSAGE CHAIR (A58214)
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
